1999 gs300 Crank no start
My cousin's 1999 gs300 was running fine before she stopped using it for a few days. Now we have crank no start issue with little sputtering like it wants to start. I sprayed some starter fluid in it and on the third crank after spraying the car sputtered harder than before.
Checked fuses (all good), no codes (we used a very cheapo one from harbor freight), checked fuel pump (by listening to it, it is making some whizzing noises), checked battery (AutoZone said it was fine), security light turns off when key is in. Spark plugs tester is on its way so I haven't tested for spark but when I removed one of the wires, it was soaked in oil. Also, we took it to a shop before it started acting up for state and emissions and the flagged an O2 sensor. We haven't replaced it yet, but I don't know if that would cause all this.
Any help is appreciated. I am tempted to order a new fuel pump but I don't know for sure if that's the issue as it is making noises.
Thanks 😊
Edit: I got it started by aggressively pumping the gas and cranking it. It took about 5 tried but it's running now. Is this normal if they car hasn't been running for a week?
Thanks 😊
Thanks 😊
Thanks 😊
Thanks 😊
Thanks 😊
pakiman626
04-18-23 12:13 PM
