my diy chrome grille story
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
After doing a bit of research on CL I decided to do the ol' DIY chrome grille bit. I got my equipment in accordance to some posts here: gel-type circa 1850 paint remover, a toothbrush, q-tips, toothpicks, towels, you get the point. My project was a tad too ambitious, I wanted to go with the "ghetto" full chrome grille. Taking the advice of my predecessors I slapped the shiat on and got to work. After probably 8-10 gruelling hours over 2 days I got as far as the job could take me. I now have a mostly chrome grille. The fronts of the fins look beautiful. The insides look dirty and in some areas the chrome chipped and bubbled off and revealed ugly white plastic. I've done the best I could do with it given my initial goal, and will live with it for now, but I feel I should share my experience with you fellas.
My advice: If you're going to take this route with your grille, just remove the paint from the fronts of the fins and leave the rest.
Anyone know where I can get a 2001+ chrome grille cheap?
1st of all a full chrome grille is not "GHETTO". Anyway, I have a 2001 chrome grille and it looks better than any other GS grille i've ever seen, people stare at it because it looks so classy on the crystal white paint, and adds an extra touch 2 the 20inchs chrome shoes....
i used laquer thinner and a sock to rub the paint of just the outer part of the fins. absolutely no problems..infact, bluelex recommended the thinner as opposed to the paint remover.
took about 2 hours...and made my fingers feel like sandpaper srubbed them
If no chrome came off the tops of the fins, you can just repaint the whole thing black again and then wipe off the paint from the tops of the fins so it looks like Koreanpers. If you still don't like it you could just repaint it again so it looks stock until you can find a fully chromed grill.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
koreanpers - I'll try to further clean it up with laquer thinner. It's not looking that bad, it just looks dirty from some angles.
I thought about painting the inside of the fins, but just the back half past the ridge. It's something to consider, but I'm not to gung-ho about the idea right now.
Thanks for the replies and your pity.
I don't think it's ghetto either, I was quoting someone in one of the old DIY chrome grille threads. I wouldn't have tried for full chrome if I really thought it was ghetto.
Same story with me. I live in the UK though so havent access to the products you have in the USA. I tried a few UK strippers / grafitti removers ect. The front of each grill came off like a dream, but it was time consuming. I melted 3 toothbrushes and 2 pairs of industrial gloves, the fumes were giveing me an awful throat (I then used a vapour mask) then finally after 3 nights scrubbing away until late I gave up and although it looks chrome all over from a meter or 2 away, inside between the grill is a lot of gunge I couldn;t scrape out, and I tried allsorts of tools, beleive me! Next time Id rather pay the $200+ for a chrome grill. It turned into a horrible chore and headache.
I was lucky for not doing the whole grill but only the front after found out that it took much of the rubbing to reveal the chrome. I used acetone and it seemed to work OK, except that my thumb ... ouch ouch.
