Am2 fuse keeps blowing
Hey guys made a post couple days ago about my car not cranking, turns off my am2 fuse blows once I turn my key to the on position. I’ve replaced each ignition coil connector. I have tried starting it without the ignition fuse(it still blows without the fuse), tried it without the igniter connected. I found this diagram on the forums I just wanna know if it’s just the ignition switch that can blow the am2 fuse? Or can the neutral safety switch blow it as well? I did check the starter by jumping it with wire (because the car doesn’t crank) and it does engage.
What did you ever end up doing
65gt350
01-08-18 12:30 PM
