Front End suspension/steering
Have an 01 GS300 that just turned 107k, new rotors and pads 2k ago, now I have a creaking noise on acceleration and breaking and some turning on the right front. Was hoping to find a good rebuild kit with bushings, lower control arms were replaced around 95k, steering is what I would describe as a “wanderer” and wondered if anyone had any success suggestions. First time here, appreciate any help.
Many possibilities. If you are trying to shotgun the issue, RockAuto has a lot of replacement parts. Look into Figs Engineering for performance packages.
The following 2 users liked this post by TrueGS300:
QLex300 (04-10-22),
RikiHernan (04-15-22)
QLex300 (04-10-22)
The upper ball joint is on the end of the front upper control arm (FUCA), and it is not replaceable. The whole FUCA must be replaced, but they are not that expensive. Left FUCA 48630-39055 , Right FUCA 48610-39085.
The front lower ball joint is mounted to a small assembly, separate from the lower control arm, and is somewhat easy to replace. Left 43340-39415, Right 43330-39535 (1999+).
The third ball joint on the front end is found on the end of the steering link. Must align the car after replacing. Left 45470-59015, Right 45460-59015.
Also check the anti-sway bar mounts, brake rotor bolts, upper strut mount nuts, steering rack bushings, transmission mounts.
QLex300 (04-10-22)
HI,
Just did the following to mine:
Ball Joints
Lower & Upper Control Arms
Sway Arm Bushings
Control Arm Bushings
**Going to replace the A cross member next**
100% difference
Ball Joints
Sway Arm Bushings
100% difference
