What size adapters for knuckle bushings?
I’m going to rent the ball joint kit from AutoZone but I read somewhere I need an adapter to press out the knuckle bushings? Does anyone know which one it is or if the kit AutoZone gives you would come with that?
Thanks in advance
Thanks in advance
I replaced the rear wheel lower knuckle bushing, left and right, on my 2000 Avalon. Very similar if you’re doing the lower knuckle bushing on each of the rear wheels. I used a sharp knife and cut off the rubber outer lip on the inner side of the bushing and knocked the bushing out with a hammer, the old bushing was actually a bit loose in the knuckle and cutting off the outer lip allowed it to be driven out easily. I used a ball joint press to press in the new dorman bushings which came with aluminum adapters to assist installation, I was able to clean out the knuckle with some fine grit sandpaper, lube the knuckle and bushing with silicone brake lube and press the bushing in, it took a few tries on the 1st side but once I figured it out the 2nd side was much easier. I’m talking about the very bottom bushing on the knuckle where a single arm runs forward to a mounting location at the front of each rear wheel well. Hope his helps.
QLex300 (04-19-22)
It’s been a long time but I remember getting out the old ones easily but needing to buy this to get the new ones on. https://www.autozone.com/test-scan-a...B&gclsrc=aw.ds
I have an OTC ball joint press, similar to the one lexo98 posted a link for, mine is older and has less adapters than that one does. I found the trick for me was to use sandpaper to clean the knuckle bore that the bushing presses into, I used silicon brake lube, won’t harm the rubber bushings that way. I didn’t use any adapters, I put a flat metal washer, a big one, over the open end of the knuckle, to keep the c clamp centered, then pressed against the metal center of the replacement bushing with the c clamps forcing screw, use the lube generously because you must get the oversized rubber edge of the new bushing started and then pressed through the knuckle, once I got the bushing about 90% in, I removed the c clamp and washer, then gave the new bushing a few gentle taps with the hammer to finish the installation, the problem was the c clamp kept getting cocked and popping off the bushing, I did it alone on my back in my garage and eventually I got it. I had to make sure I oriented the replacement bushing correctly too, it seems that there are 2 spaces open on the bushing, I oriented then identical to the old ones. I used a closed end hand wrench, not a pneumatic air tool on the c clamp. It was a bit like a monkey and a football, if you’re familiar with the expression, I’m keeping it G rated, lol.
Mine were squeaking too, funny it did it more after raining and drying out, I did the same with spray lube, WD40 as I recall, that’s how I ruled out what it was or was not. I’m from Rochester, now I live in Florida. I see you’re Brooklyn? Is your cars under body fairly clean?? I don’t miss working on all the northern vehicles, I’m a tech for a large fleet, now I hardly ever use a torch anymore, many coworkers have never used a torch, which I found crazy.
Mine also didn’t affect the alignment much, as I recall. Maybe a bit of a clunk on takeoff sometimes, they had a bit of play in the old ones, New one was quiet on both sides.
thanks. I’m definitely going to do them then. I’m sure they’re shot if they were squeaking and it will help tighten up the rear.
