Crank no start no spark
1st Gear
Hello everyone, have a 2jzge. Recently I had to head gasket was getting water in oil. I also did the timing belt water pump and all seals and o rings.I have put it all back together but won't start.checked the plugs for spark and nothing. So I have changed the cam and crank sensors and still no spark. Can any please help direct in the right direction. It's greatly appreciated
Change the plugs, coils n wires are most likely fine, those other parts weren’t needed
always start with the least expensive parts if you’re gonna throw $$ at the problem, but throwing parts at a problem isn’t the way.
QLex300 (05-20-22)
lsflame
Performance & Maintenance
11-13-06 07:28 PM
