Aristo (Gs300) Climate control unit swap problem
To get it working you will need to figure out how to use a us HVAC with the aristo. Then that board will be used to interface with the full replacement android unit. The full replacement android units are designed to work with the us HVAC units (you remove the board from the inside and plug it into their interface). The us HVAC don't quite work right with the aristo. I suspect some wires just need to be swapped around. I removed my nav unit and just use the android 9" screen with a JDM aristo multidisplay for the time being until I have time to sort it all out.
Also the platic doesnt quite fit right on the aristo. It's curved towards the passenger and some gaps. But you can get it to fit ok with some force.
I bought the teyes cc3. I put a navifly m6 pro in my is300. I would pick the navifly next time. Mekede also makes a decent unit.
They are all actually the same units, just slightly different packaging, ram/storage/screen options and different software. The 2k versions have some updated hardware. There is a new version to release this year for all the brands.
Stay away from the other brands, and personally I would avoid teyes as well. From my testing navifly then mekede then teyes and then everything else is junk.
Both my cars are running ATOTO S8 Plus and Ultra Stereos. I like that they have 2 external camera inputs that are easy to activate. I have a backup camera, and a front parking camera that keeps my lowered front clip safe from curbs! Some models also have optical out, which I use for my JL Audio amps. No alternator whine or other noise is introduced, like with RCA cables. ATOTO stereos aren't perfect, but overall they're great.
CurlyG (03-15-24)
