Gs300 keyfob/locks
5th Gear
Gs300 keyfob/locks
I bought a 98 gs300 back in December and at first the remote didn’t work and had to use the key manually to unlock/lock the doors, this was fine but I had to keep turning the key until I heard 2 clicks otherwise the alarm would go off. Now for the past 2 weeks the remote randomly worked but it wouldn’t unlock if I locked the car with the actual key, now today the remote dosent work. Also if I use the lock button in the car it clicks then clicks again. Would anyone know any causes?
why don't you change the battery first. if you only has one key I suggest you get another before further problems. when you open back trunk you need to hold the button for say 1 second. for side doors you press once for driver and two for all doors.
I used to fab the 2nd key and learn it myself, but then learning process for other keys are failed. Lexus has so many different type of remote, no way to make sure it works for your car unless you go expensive dealer.
5th Gear
lanvinau
01-12-07 12:49 AM
