does anyone know how to fix (rattling from glovebox area)
does anyone know how to fix....
I have this really annoying rattling coming from my glovebox area while driving. It so loud, that I can hear it over the stereo(NAK). But then when, I put my CD holder case in the glove box underneath the changer, the rattling goes away?! Just wanted to ask all of you, if you have similar poblems with rattling from the glove box area, and how did you fix it! thanks, in advance
It's a defect, Lexus Dealer should be able to fix it for you for free! What year is your ride? I remember this issue was discussed awhile ago... Anyone disagreed?
The One
Originally posted by PHML
Take it back to the dealer....there's a TSB on it....all they do is added a few rubber pads at strategic locations.
Brother Neo,
Listen, You will be fully accommondated by Lexus, since it's a DEFECT! They will have to FIX it no matter what. It's a KNOWN issue, they will fix it.... otherwise just call the Satisfaction hotline and the result will be the same: They will fix it!
To save your time and trouble, call the hotline and then the dealer!
Stupid glove compartment drives you crazy!
The One
Originally posted by chuckisc
Brother Neo,
Brother Neo,
What is the hotline? Also, if it is a known defect, are they required to fix it w/o charge? I don't believe so because I cannot get them to fix that steering wheel shake unless I pay $700.
Master Thread Closer!!
Originally posted by Neo
...Is there a TSB number? I'd like to be armed with as much info as possible when I "confront" Lexus....
Pete
Bulletins for 2000 Lexus GS 300 L6-3.0L DOHC (2JZ-GE) MFI
Service Bulletins
TSB # Issue Date TSB Title
TC002-03 MAY 03 Engine Controls - ECM Reset Memory Function
EG001-03 FEB 03 Exhaust System - Sulfur Smell
BO006-02 NOV 02 Interior - Correct Cup Holder Installation
PG012-02 OCT 02 Suspension - Ball Joint Inspection Method
TC001-02 MAY 02 A/T - Fluid Requirements
EG002-02 FEB 02 OBD II - Readiness Monitor Drive Patterns
PG002-02 JAN 02 Certification Label - Replacement Availability
PG001-02 JAN 02 Corrections Index - Repair Manual
SU003-02 JAN 02 Front Stabilizer Bar - Abnormal Noise on Turns/Bumps
PG003-02 JAN 02 VIN Plate - Replacement Availability
BO001R-01 NOV 01 Seat Belts - Extender Availability Update
AX001R-01 MAY 01 Trunk - Retrofit Internal Release Kits
EG002-01 APR 01 EVAP System - Design/Operation/Diagnostics
NV005-01 MAR 01 Glove Box - Rattling Noise
BO005-01 MAR 01 Seat Belt - Revised Tongue Plate Stopper
BO003-01 MAR 01 Headlamp - Service Parts Availability
AX001-01 MAR 01 Internal Trunk Release - Retrofit Kits
ST001-01 FEB 01 Steering Wheel Nut - Torque Standardization
BO001-01 JAN 01 Seat Belts - Extenders
AC001-01 JAN 01 A/C Indicators - Malfunction
PG017-99 DEC 00 Vehicle - Year 2000 Readiness Disclosure
EL008-99 DEC 00 Engine Immobilizer System - Precautions
SS003-00 DEC 00 Diagnostic Tester - Communication Error w/TIS
BR003-00 OCT 00 Brakes - Clicking Noise Upon Application
SS002-00 OCT 00 EVAP System - Special Tool Upgrade
SS001-00 SEP 00 Special Service Tools
NV009-00 JUL 00 Window Seal - Wind Noise From Front Windows
PG005-00 JUL 00 Service Manual - Page Corrections
BO006-00 JUL 00 Interior - Seat Belt Extender
AC001-00 JUL 00 A/C - Compressor Maintenance During Storage
PA002-00 JUN 00 Paint - Exterior Color Information
NV005-00 APR 00 Center Seat Belt Retractor Cover - Rattle
PG001-00 APR 00 CA/50 State Certified Emission Control Label Ordering
AX001-00 MAR 00 Towing - Dinghy Towing (Four Wheels On the Ground)
NV001-00 JAN 00 Garage Door Opener - Rattles
NV003-00 JAN 00 Glove Box - Rattle Noise
BO005-99 DEC 99 Seat Belt Extender - Availability
SU001-99 SEP 99 Wheel Balance - Adjustment Procedure
AC001-97 SEP 97 A/C - Musty Odor
PG003-97 JUL 97 Certification Labels - Replacement Policy
PG002-97 MAR 97 Air Bag - Information Label On Glove Box Door
PG002-96 APR 96 Emission Control Label Order Form CA/50 State Certified
BO93-007 JUL 93 License Plate - Front And Rear Installation Procedure
PG93-004 MAY 93 A/C - Ozone Depleting Substance Caution Labels
PG93-003 APR 93 Vin Plates/Certification Labels - Replacement
PGI004 SEP 91 Recycled Coolant - Usage Recommendations
BODY026 AUG 91 Body - Permanent Type Protective Wax Coatings
Some has the retentioner tighten up and that will fix it... do a search on "Stearingwheel vibration" etc.
No, You do not have to pay $700 man.
Hey Pete,
do you have TSB for a 99' GS300 ? Thanks man
Hey Pete,
Here you go bro. Notice there are more 1999 TSBs on this list.
Pete
Bulletins for 1999 Lexus GS 300 L6-3.0L DOHC (2JZ-GE) MFI
Service Bulletins
ST002-00 APR 00 Steering Column - Slider Sub Assembly Available
BO004-99 DEC 99 Moonroof - Creak Noise Reduction
TC003-99 SEP 99 A/T - Fluid Recommendations
SS007-99 JUL 99 SST Program - Special Service Tools
SS006-99 JUN 99 Scantool Immobilizer - Key Code Utility
SS004-99 JUN 99 Wireless Recognition Codes - Alternate Register Method
PA002-99 MAY 99 Paint - Refinish Formula Codes
BO002-99 APR 99 Glove Box Switch - Rattle Noise
SS001-99 APR 99 Diagnostic Tester - Customize Program Card Update
TC001-99 APR 99 Drive Shaft - Grease Revision
AU001-99 APR 99 AM Radio - Crosstalk Interference
AX003-99 MAR 99 Dinghy Towing Guide - With Four Wheels on the Ground
EL002-99 MAR 99 Antitheft - Troubleshooting Immobilizer DTC B2795
EL003-99 MAR 99 Antitheft - Troubleshooting Immobilizer DTC B2796
PA001-99 MAR 99 Paint - Colors
PG001-99 JAN 99 TSIB - Volume 4 Information
TC005-98 DEC 98 ECM/TCM - Diagnostic Tester Reset Memory Function
SS002-98 DEC 98 Tools - Installing Rivet Nuts
The One
Are these cumulative? Meaning that the ones dated in 2001 affects the previous year models too or just that year. I have a 98 and I see actually 2 glovebox rattle TSBs on the 00 and 99 lists. Does this mean it affects my year too? And you guys are sure they will fix these even after warranty is gone?
glovebox fix
the best thing to use is felt. place the felt around the perimeter of the glovebox in the inside, especially where the peg that activates the light in the glovebox. lexus did the initial placing of the felt, unfortunately they charged b/c car was out of warranty. i added somemore felt and haven't had a problem since.
The One
Re: glovebox fix
