I just bought a 2007 Lexus gs350 with 216k miles I immediately per norm changed cabin air filter and engine air filter. Motor oil I believe has either 4k or 8k on it judging by the odometer trip meter. I found the drain plug for motor oil though the pan looks different than everyone on each video I watch for the same year and model. Then for the filter I guess it’s different than ones I’ve had ie. Honda Acura Chrysler Saturn. And also tried spotting it by peeling under the splash shield that’s on the bottom front end from videos it looks like it’s in the front center of the car this is accurate correct? If I get some responses I’ll
take some pictures of the described locations I am talking about and seeing and if some could be shown that would be helpful. Also attached is the cabin and the engine filter. I was shocked 😮
I honestly have never seen “worse”.
Upon purchase I was told it needs control arms and ball joints. There is a what sounds like a quiet rattle sometimes over bumps it sounds like it’s coming from the driver side when I looked a little on the driver side and every thing looked fine on the passenger side the pretty sure cv joint the rubber looks in attached where it should have a metal clip closing it and it looks exposed could take a picture I’d the description isn’t clear enough also woundering I know it’s a long shot but on the driver side the wheel splash shield the front half is missing there’s also a piece of plastic that looks like part of it is missing can any one identify the part that’s there and what is missing
