under body shield nuts
9th Gear
I know there are a whole bunch of shields under the body of these cars and most use a 10mm head screw. The end of the shield that you have to drop to change the oil has two long screws that are at the back end of the shield. Does anyone know the size of these nuts? They seem to be plastic with a large build in washer. They are only two but I also see the same nuts on the shields that go under the bottom of where the door sits.
