GS 2008 starter strange noise
Hey guy's...
My 2008 GS300 make this noise when I start specially in cold start. Sometime the noise disappeare for a couple of days and then comeback.
Any adeas?
Appreciate your help
Audio attached for the noise
Any adeas?
Sounds like the starter solenoid is not returning, the gear. Maybe more likely the shaft of the starter needs lube. Maybe if you remove the starter, clean the shaft and grease it. Worst case buy a used starter on www.car-parts.com you can find newer model cars and the price is so cheap. or buy a denso starter from rockauto, I would avoid cheap china aftermarket
sam89 (02-20-24)
I would also fix this soon, as what can happen if you keep letting the starter gear grind. That sound is the gear bouncing off the flywheel. It can do damage to the flywheel and destroy the teeth. If that happens then the transmission needs to be removed and you will need to buy a new flywheel. So fix it asap, and when you remove the starter examine the flywheel for damage.
sam89 (02-20-24)
The starter is replaced, old one is near life. swapped it for used OEM Denso around 150$ including labor. It was really painful for the technician because there is no room to work and it is probably the original 2008 starter so it was tough to get it out it took around 45 minutes.
Flywheel is not damaged thank God.
sam89 (02-26-24)
camn
10-13-21 04:40 PM
wckd2022
RX - 1st Gen (1999-2003)
07-06-05 06:09 PM
