Car would not respond to throttle check engine light came on
1st Gear
I was driving on the freeway and the check engine light came on and the car just slowed down. I kept pressing the gas pedal with no response. I shut off the car and cut it back on and it drove fine but the engine light stayed on. I got p2102 code but i i also checked the abs codes and it had a c1241 and a few other codes dealing with the wheel sensors. Not sure where to go from here. Any help will be greatly appreciated.
Have you ever unplugged and removed the throttle body,then fully cleaned it out?
