Couple questions for people in the KNOW
Two questions, does anyone know if the rear windows roll down as far as it can, is it submerged in the door or can you still see part of the window? And other than recognize the drive when you walk close to the car, does the key fob do anything else? Like open all the windows and sunroof remotely. And does it recognize different key fobs, like if I walked up to it, it would adjust the seat and steering wheel the way I like it, and then if my girlfriend uses it, it would adjust the setting to her specs. I know a lot of other cars do that, but I haven't seen anything about it with this car.
1.yes that is thwe windown all the way down in the rear
2.from the key as as far as i know you can lower all the windows and open the sunroof
but not raise them and you can open the trunk
Rear window and key fob features
Actually the windows leave about a half an inch peaking out at the B pillar side and it slopes down from there into the window groove for about 8 inches or so. Hardly noticable though.
The key fob can bring down the windows and open the sunroof by just holding down the unlock button. To go up you must remove the metal key end and insert into the driver's door lock and turn it to the left and hold until the windows and roof are shut.
The car knows you are there at about 3 ft. Once you touch any handle of any door on the inside of the handle it will unlock that particular door. You can program it to open two doors on one side and also have all doors unlock on contact with any handle. That's up to you.
It doesn't do seat and steering wheel settings. The GS comes with 3 preset positions on the Driver and front Passenger seats so all you have to do is push your button when changing drivers. You can walk up to the trunk and just touch underneath the sash and it releases for you. Don't slam it shut as it has a power closer so all you do is gently let it make contact.
sc00b
03-21-14 02:35 AM
