XM installation
I think AZMIKE said that he had his dealer install the XM inside the rear deck lip...Does anyone have a picture of a similar installation, or AZMIKE, if you see this, can you please post a picture? Thanks,
This is a very important topic. We need someone to get instructions on how to do this. Rockville tried to have this done to a demo car, but they need some assistance as well. Please post instructions and pictures of an install if possible to help everyone out.
The tech just have to remove the back seat, the passenger side " C" pillar, then lift up the rear deck so he got enough room to put his hand in there and mount the antenna.
Then the tech just have to find some small access and feed the antenna wires through the trunk. Any tech with some common sense will figure this out. We did about 6 GS's this way and not a single problem, but a lot of time consumtion.
so when you look at the car, where do you see the antenna mounted that method...is it sort of inside the rear window so it has a clear view of the sky for the signal?
The Godfather
02-16-08 04:57 PM
