Work Around for DVD/Nav? (Operate while car is in Motion)
According to my research...
The DVD will not work unless the speed sensor is also disconnected. Also, there are two purple wires, perhaps I've tested the wrong one. I probed the purple wire near the red one and closest to the steering wheel.
When this purple wire is broken, the Nav will accept destinations as well as the telephone buttons are active. Any ideas, I'd love to solve this before I put things back to normal.
Guest
Posts: n/a
And hint, it does have something to do with the speed sensor....
Well there are two purple wires. I choose the one nearest the red. I cannot determine the wire numbers from the connector (not certain where #1 is to begin counting)
The funny thing is, the PB is defeated, but the DVD will not play unless the speed sensor is defeated too. But that speed sensor wire (the purple I switched) also controls the NAV. In the GX, the speed sensor wire for the DVD was separate from the NAV Speed sensor. So you would need to disrupt three wires. One switched for the Nav, and two always disrupted for the DVD (from my recollection). My GX is back to factory, btw.
Well there are two purple wires. I choose the one nearest the red. I cannot determine the wire numbers from the connector (not certain where #1 is to begin counting).
Originally Posted by DrexLex
If I cross referenced the connector correctly, the red #14 is the last of the top row, with the violet #13 the next one, and if you continue counting down, #1 (orange) is at the opposite end of the row. The 2nd row, starts with #15 below #1, thence thru to #28 which is below #14.
There appears to be only the one SPD wire heading from the combination meter into the nav, so it looks like you got it figured out.
I tried severing the other purple wire but it disabled the backup camera placed on in reverse. Good to know I guess if you wanted to turn the backup camera on in other situations you'd need to test what is simulated from that wire.
Originally Posted by jomvinya
I'm also in desperate need of the wiring diagram....Would someone post or email it ....PLEASEEEEEEE.
Originally Posted by YL06GS
I had mine done. I can give you all the info, if you want.
I also have the Wiring Diagram from Lexus if you want.
You can take it to a shop that you have experience with or tackle it yourself.
justintime_68@hotmail.com
I live in SoCal (LA). Thanks very much! You have great info!
Could you please also send me the wiring diagram that you have. stylings300@yahoo.com
Thanks a lot.
Would you mind emailing me the name of the shop as well? Is there a contact person that has done this before so I don't have to explain it?
tim.meade@mac.com
Thanks,
TM
tim.meade@mac.com
Thanks,
TM
Could you send me the name of the place in Socal that did the DVD/NAV mod too?
rcanent@comcast.net
thanks!
rcanent@comcast.net
thanks!
I'm not positive, but playing a DVD while in motion seems to cause the DVD to become reset randomly. It appears to occur when tracks attempt to change.
Has anyone else noticed this?
