Work Around for DVD/Nav? (Operate while car is in Motion)
#106
Originally Posted by mapluv
If you pull a pin, you'll likely have a harder time pushing it back in. On the other hand, if you were to cut the wrong wire, it is relatively easy to put the cut ends back together. Don't even need a solder iron.
1. Remove the three terminals from the connectors.
2. Buy a repair terminal/wire (82998-12750) from dealer ($13) for the yellow wire
3. Snap the repair terminal/wire into the connector and place a lug on the other and hook it to ground.
4. Tape back the original yellow wire to the harness.
5. Connect the other two female wire terminals together using a small male terminal or wire, a small amount of solder on them, or some other secure connection.
6. Place electrical tape around the two connected terminals to protect them.
With this method or something like it, no wires are cut and you can return the car back to stock condition in a few minutes by just snapping the pins back into the connectors.
#107
Originally Posted by dprice
Worked like a charm!
Was going to do this mod for a friend of mine and was wondering if anybody knows of where I can get those same OEM connectors. Going to need the male and the female since I basically want to do the mod outside of the car and just open up the dash and slip the harness in between.
Part number for K46 connector? H1 Connector?
#110
Shoot me an email If you live within the San Diego, California area and want to enable your DVD system and not void your warranty by cutting wires. My buddy and myself both have kits made up to do it without clipping anything. rickatencio@yahoo.com
#111
Originally Posted by krburell
The part number of K46 is 90980-12203 and H1 is 90980-12153. The mate for K46 is 90980-12202 and the H1 mate is 90980-12152. K46 and H1 can be ordered at any Toyota dealer. I do not think the mates to both of them are available but you can check.
i checked those part #s on www.1sttoyotaparts.com and none of them worked. by anychance do any of you guys know a dealership, toyota or lexus, online will have these part#s working that i can order? i need them to redo my cousins dvd mod. thanks.
what do you mean by mate? is that the pins, or a female plug for hte k46 and h1 plug?
i did the mod like you stated above that post i quoted, except grounded the wrong side. ahha
#115
Just read the instructions that ScaryH22 posted, it word perfectly. Very easy as well. There also is a link somewhere in this thread that will show you how to disassemble the nav unit. I would perform this for you if you were in Florida....LOL
#118
Coastal Tech
Originally Posted by rdwatson
any progress with disabling this "safety feature"?
Has anyone actually received their order yet? Seems like orders were placed, but delivery times were months away...
#119
Originally Posted by PeteV
There was a company, Coastal Tech, that I recall many CL members had orders placed for a wiring harness that worked around the DVD and the "I agree" screen.
#120
Originally Posted by EyeKutr
is this the exact same procedure if you have a non-Nav GS300, I just want to enable bluetooth on my non-nav vehicle...Thanks in advance
Anyone know the answer ??
