Removing Nav screen of the 2006 GS(Pics)
Old 03-24-05, 07:48 PM
VVT-i
VVT-i's Avatar
Default Removing Nav screen of the 2006 GS(Pics)
You will need a small flat head screw driver, a phillip head screw driver, a 10mm socket and a towel to protect the navigation unit.
First, remove the plastic trim underneath the nav( just right above the ashtray) by pry it out with a small flat head screw driver.
Hint: Tape the screw driver with Scotch tape to protect the finish of the trim.
Old 03-24-05, 07:52 PM
VVT-i
VVT-i's Avatar
Second, put the shifter into "D" position. DO NOT START THE CAR. Just press the start buttom twice( foot of brake pedal at this time) and put the shifter to " D" or you can remove the shift lock tab and press the buttom, so you can move the shifter to " D"
Unscrew the shifter and pry up on the center console.
Old 03-24-05, 07:54 PM
VVT-i
VVT-i's Avatar
Third, remove the phillip head screw on each side of the side cover and the pry out.
How about the Lexus screw driver?...
Old 03-24-05, 08:10 PM
VVT-i
VVT-i's Avatar
Gently remove both covers.
Old 03-24-05, 08:14 PM
VVT-i
VVT-i's Avatar
After that you will see 4 10mm bolts( 2 on each side). Remove those bolts from the nav screen bracket and remove the nav unit.
If you look under the nav unit you will find a piece of metal bracket on each side to grab onto and pull it out. Do not pry on the side of the Nav unit or try to remove the AC vent.
Old 03-24-05, 08:16 PM
VVT-i
VVT-i's Avatar
One more.
Oh, the AC vent is part of the dash. If you attemt ot remove it... you will have yourself a new dash.
Old 03-24-05, 09:08 PM
chuckb
chuckb's Avatar
you pretty brave. I'd be sweating bullets if that was my brand new GS and I was taking it apart
Old 03-24-05, 09:18 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,257 Likes on 1,371 Posts
VVT-I is this one yours or a customer car?
Old 03-24-05, 09:55 PM
saabfan
saabfan's Avatar
But why?
Old 03-24-05, 10:01 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Brave is right!
Old 03-24-05, 10:06 PM
rominl
exclusive matchup
rominl's Avatar
wow this is some good pics man, so anyone wanna take theirs apart as well?
Old 03-25-05, 12:24 AM
Neo
The One
Neo's Avatar
Great info, but how come you had to do this already?
Old 03-25-05, 12:30 AM
rominl
exclusive matchup
rominl's Avatar
being a master tech you gotta try everything
Old 03-25-05, 02:37 AM
jtanoyo1
jtanoyo1's Avatar
OMG, it pains me so.....
U a brave brave man!!!!!!!
Old 03-25-05, 03:58 AM
Baptizer
Baptizer's Avatar
if your going to be doing the dvd mod, did you take pics of that as well?
Quick Reply: Removing Nav screen of the 2006 GS(Pics)
