Lcd screen on the new GS
Hi
I want to ask about the Lcd screen on the new GS
What are the massags ??
I know its about the key and the doors what else ?
Iam sory for my bad English
Z E Z O
Z E Z O
What kind of messages are you referring to?
The one that shows up when you turn on the car?
Or the NAVI functions? (which are many)
Or are you referring to voice commands?
You'll receive messages like this
- Key Not Detected - if the key is not close to the vehicle and it is running
- Shift to P ~ - If one of the doors is ajar and you are in gear.
- Anything linked to the ! indicator. Basically Lexus has added a ! indicator in the instrument panel. When you see that illuminated, look at this display and you'll see a message of the exact problem. I.e., ABS, VGRS issue, etc.
- Also, and not mentioned here yet is the current MPG which has a bar graph.
Also this is where all the Cruise Control feedback is found. If you have Radar Cruise you will see your Cruise Control Speed and a car icon. When you approach another car an icon for the approaching car will show up in front of your car icon. The proximity to the cars in front is adjusted via a paddle on the steering wheel. This proximity is also reflected on the Cruise Control screen as lines above your car icon. If automatic braking is required a BRAKE indicator will also show up.
Lexus Connoisseur
Has over 30 different messages to display. Some:
Hood Open
Trunk Open
Moonroof open
Park Brake (show when vehicle is moved with brake applied)
Check Headlight (leveling system malfunction)
Rear Lights
Low Washer Fulid
Low Oil Pressure
Oil Maint Reqd
Oil Maint Reqd Soon
Oil Maint Reset (shows during reset of the above msg)
Check VGRS (430 only)
Check 4WD (300 AWD only)
Low Tire
Pressure Initial (Shows dureing intial calibration of tire press sensors)
Key Not Detected
Low Key Battery
Check S/T ( Steeing lock malfunction)
S/T Is not ulocked
Sonar Park Assisst System using this area while in use
Radar Cruise system Uses this area while in use
Cruise Not available (if system is having trouble calculating Car to Car distance)
Check Cruise system
Check PCS
PCS Disabled now
That is most of them. Hope that helps.
--Pete
Hood Open
Trunk Open
Moonroof open
Rear Lights
Low Washer Fulid
Low Oil Pressure
Oil Maint Reqd
Oil Maint Reqd Soon
Low Tire
Key Not Detected
Low Key Battery
S/T Is not ulocked
Check Cruise system
Check PCS
PCS Disabled now
--Pete
peasodos
12-10-17 03:57 PM
ivan1
RX - 1st Gen (1999-2003)
11-02-09 08:07 PM
