10K Service on GS430....Possible Front Rotor Issue
man highmiles, you do crank on some miles. sounds like you're enjoying your new ride
I have not even put 10k on my car yet and I've had it almost a year!
did you notice it is faster since it is broken in? after 3k, 5k or what? just curious
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I have noticed a slight vibration in the brake pedal when making a gradual (not hard) stop in my GS430. Is this the "pulsing" you were feeling? I just thought it was a characteristic of the new braking system. I doesn't seem to happen under hard stops. Did it go away with the new roters and pads? Inquiring minds want to know.
The GS 430 has a new "drive-by-wire" braking system... aka electrical
Also, according to one of my Lexus tests.. haha "The 06 GS brake pads are made of long lasting brake pad material for long term use".. the answer was FALSE...
so I think it's a combination of the braking software on the few models PLUS the material they are now using on the pads and (not sure) rotors.
Sounds like you have one the first batch of GS430s with the coated Rotors that need to be replaced. As I mentioned my sources say that this condition has been fixed at the Factory in Japan. Only those of us that took early delivery of our GS430s are effected. None of the GS300s have the same problem as their braking system is different.
testmetest
IS F (2008-2014)
17
12-05-11 04:47 PM
