Main Lights connected with ON/OFF button?
Originally Posted by Ex996
You know, I may have been thinking about 2nd gen. I wish someone would post the 3 Gen C-BEST settings.
Is that what you were looking for?
Originally Posted by sung35
Leave the light switch at the "ON" position instead of "AUTO". The light will turn automatically turn off after close all the doors.
leaving the swith on "AUTO" will turn the ligths off when in bright daylight, which is quite common here in Italy.
Does anybody know if I can set up the lights so that also the secondary lights will switch off after closing the doors?
Thanks,
Claudio
Originally Posted by JHStrange
I had the dealer change the setting on the headlights so they go off when the engine is turned off and the driver door opened. This is the way our '95GS worked and we preferred it. We ran it with the lights on all the time but now with the '06 having daytime running lights we just leave the main headlights on Auto.
Sounds like this would give you the result you're after.
I would pass them onto mine and have the same settings.
