screen went dim on me
Originally Posted by foofighter
warranty time
this along w/:
constant alignment issue
windnoise leaking in from sunroof
flickering rear view camera
back panel headrest falling off
Originally Posted by frebay
i know...
this along w/:
I thought i bought a lexus.
this along w/:
Also, the dashboard dimming was a problem in the 2nd generation GS. It happened to me a couple of times but it went away on it's own.
Just out of curiosity,. did you have the windows tinted or do you have any parking permits on the dash/rear view mirror. I believe there are sensors around the cabin to adjust the display according to the outside ambient light.
You probably didn't do this...but did you adjust the instrument panel brightness? Is the exterior lighting sensor working? Is night mode on? And did you try adjusting brightness settings, or deactivating the screen and reactivating it? Just checking before you sent it in.
Lexus Connoisseur
![](https://www.clublexus.com/gallery/data/500/605Longo15.jpg)
it's not the dashbaord, just the navi screen. the map turned into a shade of black. it was weird.
Are you the only driver of this car?
Originally Posted by bigzip
Maybe you have it on night mode. Push Disp then make sure day mode is highlighted.
Last night when this happened, I thought it might have been a display problem, so I went to display and saw a night mode button. Today, I don't see that night mode button anymore. How do I enable the night mode button? I tried turning on the headlights, but the night mode button didn't show up. Also when I pressed the light mode button, the screen became faded. When I pressed it again, the screen turned very dark.
Please refer to the owner's manual page 252 and Nav's manual page 113. There's a misprint that tell you about turn the light control switch all the way to the right, actually they're saying if you press the " MAX" buttom the Day Mode or Night Mode will dissappear.
If you don't want your screen to flickering just press the MAX buttom. If the MAX setting is too bright for you then you just press the arrow key, but the screen will become very sensitive to the light.
You can go to " MENU", select Screen Setting, scroll down until you see Day Mode or Night Mode and you will see the high light said " Normal", under that you can adjust the setting from 1 to 4 depending on how you like your screen to be darker or brighter.
If it's the ol' Night Mode and dashboard lighting thing again, then its not uncommon. There have been posts about this, such as the time the cabin lights wouldn't go on because the instrument panel light was set to MIN lowest, and the time the Night Mode refused to come on because the light was set on MAX.
Can some1 tell me what the red button is for on the keyfob in Flipside's picture? Don't have that on my (Dutch) keyfob (as many other options on the European '06 GS430 btw)
Originally Posted by lebaron97
Can some1 tell me what the red button is for on the keyfob in Flipside's picture? Don't have that on my (Dutch) keyfob (as many other options on the European '06 GS430 btw) ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
