Last edit by: IB Advertising
Browse all: Steering and Suspension
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
Official 3rd Gen GS Modification Thread!!
#1430
Guest
Posts: n/a
#1435
LED Turn Signals- Solved w/ NO fast flashing (products and install)
I have an 07 GS350. I was sick of the orange bulbs so I bought these off of ijdmtoy.com ( https://store.ijdmtoy.com/ProductDet...40_7443_SKU201 ). 2 sets. When you install them you will get a fast flash that is obnoxious. You must install load resistors ( https://store.ijdmtoy.com/ProductDet..._Load_Resistor ) parallel in each bulb's wiring. Its easier then it sounds. There are no positive and negative on the load resistor, either way is fine. A wire comes out of each end so buy some t-taps at radio shack and simply snap one wire of the load resistor into the negative wire to the bulb, and the the other load resistor wire into the positve wire to the bulb. Do this in all four corners and you are good to go. Make sure to strategically mount the load resistors on the trunk metal and up front slide them into an opening right next to the HID that is all metal, then replace the caps on the HIDs. I used electrical tape on all four corners to make sure the load resistors stay put. The end result is beautiful amber LED turn signals.
