HELP with low pressure sensors
Honestly, i have NO idea what i did other than what i described in my earlier post. But it worked on my car. I'm sorry to hear that its not working for you, i wish i could be more help....
the only other thing i can think of, is that there is yet another push button switch under the passenger side column....basically same spot as the first switch i described but this one is on the passenger side....
my dealership told me that that switch is meant for people on the east coast for when they want to put winter tires on. meant to bypass the tire pressure system so they dont have to buy 4 new sensors....
sorry i couldn't be of more help...
Originally Posted by KINGPING
blue GS.. i tried the pressing the button 5 times thing and it didnt work.. the lights keep flashing.. any update or maybe im doing it wrong??? let me know.. thanks..
Originally Posted by trent
Wow!!! There's no way the existing valve stems can be transfered over??
Most dealers don't know anything on transferring the system over. Tustin Lexus in CA, for example, said it could not be done. They showed my the door and said "good luck." If you are not in So Cal, maybe you can call the place I went to and get some pointers. www.shorelinemotoring.com. They have a pic posted of my car in the gallery, under other imports. Don't comment please, I know my car looks nasty and will continue to look that way until someone comes out with C/Os....
AK
Originally Posted by foofighter
akim47: why not run the tanabe springs till the c/o's come out?
Your car looks nice as heck...you have PM btw
i thought tein was supposed to be releasing the ss for the gs anytime now....
kinda sucks though because i hear the ss line is no good... tanabe has a c/o system that is out in japan, but they do not want to send it here. the explanation i received, was that the c/o system was tuned for japan, where i guess the streets are a lot smoother than in the states. they do not want to be held liable should something go wrong with your car, so there is additional r&d going into it before they release a us product... who knows, maybe its a bunch of bs...
ak
the other not so cool method would be to get a rear go kart wheel and tire...throw the sensors into them and inflate the tire up to 32psi...put this wheel/tire in the trunk and you're done.
koolaidman has suggested that on numerous occassions and i never understood what he meant by that until someone told me about the go kart tire trick...yes i dont see why it wouldnt work
And i'm sorry my tip didnt work
I have no idea why it would work on my car but the same procedure would not work for someone else
