GS430 failed euro Braketest!!!!
#31
Originally Posted by Christian
Hello,
. Since the GS300 and 430 have the same brakesystem but not the same suspension it would be interessting to know if the GS300 has the same problem.
Chris
Chris
#34
Hello,
are the discs different, too? Overhere the disc size of GS300/430 front and rear is the same.
Chris
Chris
both have 12.2 rear.
high friction brake pads are standard equip for GS430 front brakes only.
#35
Originally Posted by chuckb
I believe you're mistaken. the GS430 has 13.1 inch front disc and the GS300 has 11.6 inch front.
#36
Hello,
the euro GS front brakes are 334mm. The smallest wheels which will fit both GS are 17". So this means the euro GS300 has bigger brakes.
Chris
Chris
#37
Hello,
Chris
Chris
#38
Hello,
Chris
Chris
#42
http://www.stoptech.com/tech_info/Th...%20Systems.pdf
GS430 is on my target to replace my 2nd generation Acura TL, if Lexus does nothing, I will look for rear BBK for better cooling - hello larger rotor and directional vanes
#45
Originally Posted by p.hase
still no comment or bulletin from LEXUS USA? ![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Besides this test , do the brakes perform up to spec as per DOT?
