Disable seatbelt chime...
Originally Posted by bigzip
osmany, you don't use the reset button, it's the trip/odo button. Read lexuslovers p.s. in the first post.
Originally Posted by MR LEX NY
Am I An Iddoit I Cant Get This What The Hell Am I Doing Wrong Help!!!
Originally Posted by cleanm3
hahah you and me both!! damn it! is the trip/odo supposed to change when i press it the second time? cuz when i press and hold it changes to trip a. so do i still hold and buckle up anyways?
Turning off seat belt buzzer:
1) Set the LCD on the combination meter to the ODO display using the ODO/TRIP button.
2) Turn IG off. Unbuckle both front seat belts.
3) With foot off brake, press Start button twice to activate electronics. Within six seconds, press and hold the ODO/TRIP button. Wait ten seconds, and while still holding the button, buckle the driver’s seat belt.
4) The LCD displays "b-oFF". Release the button. The buzzer can be switched between "b-on" or "b-oFF" each time the ODO/TRIP button is pressed.
5) The display reverts back to normal if the button is not pressed for ten seconds, completing the process.
Repeat 2) to 5) for the passenger seat belt buzzer.
It implies that each seat can have the buzzer set independently. If the above is correct, one question--can one finish with step 4, and within 10 sec disconnect the driver's belt, then connect the passenger belt and then turn that buzzer off, thus avoiding restarting the whole process for the passenger belt? Anyone tried debuzzing both belts?
donkiboy
10-31-18 03:22 AM
