Fully disengage the GS's trac & stab control!!
don't know if this is a repost or not as i'm just a "troll" of sorts....i have a MB w210 E55 but have always loved the GS's in all it's generations, and have been reading these forums for awhile now. in the new Automobile mag it said how to fully disengage the stability and traction control function. Directly from the mag (January 2006 issue)...
" If you own a 2006 GS (or IS), follow these steps and enjoy the slide. Once the car is started, you have thirty seconds to complete the process. With practice, the procedure can be completed in about fifteen seconds but, unfortunatley, must be repeated each time the the car is switched off.
1-Make sure the car is in Park and the parking brake is disengaged before you start the car.
2-Start the engine.
3-Engage the parking brake.
4-Fully depress the brake pedal and then release.
5-Fully depress the brake pedal and then release.
6-Disengage the parking brake.
7-Fully depress and hold down the brake pedal.
8-Engage the parking brake, then disengage it (while holding down the brake pedal).
9-Engage the parking brake, then disengage it (while holding down the brake pedal).
10-Release the brake pedal.
11-Engage the parking brake.
12-Fully depress the brake pedal and then release.
13-Fully depress the brake pedal and then release.
When "Check VSC" is displayed in the multifunction display along with the "Trac-off" icon indicator, you'll know that you have successfully completed the procedure "
just trying to help out other speed junkies like myself
2-Start the engine.
haromania
01-25-16 12:48 PM
Lboogie300
05-23-06 06:32 AM
