Defective cigarette lighter
So after two months of ownership, I finally discovered that my cigarette lighter doesn't work. I don't smoke so I never tried pressing the button but I was playing around with it this past weekend because I got my V1. I noticed that it wasn't powering up when I plugged it in the socket so I took it out and just pressed the button to see if it would heat up, but the lighter never popped back up. I pulled it out and it was cold after waiting a few minutes. Just wondering if this has happened to any other 3GS owners or if I'm the first one. I already scheduled an appointment to bring it in to my local dealer.
It's probably just a fuse, or maybe you forgot to plug it back in when you removed your center console. Do you notice the lights coming on in the ashtray when your headlights are on?
I checked the fuse and it's not blown. Also, the ring of light around the lighter work fine, so that lead me to believe that there's a problem with just the lighter itself.
the same thing happened to me but after many fuse changes i founf that a little spring from a pen dropped in the hole and everytime i changed the fuse and tested it, it made the fusees blow. there are at leased two fuses that i know maybe 3 for the lighter chack all of them and check to see if anything dropped in the hole.
hope they didnt charge you for that.
oh yea i figured it out about the spring when my converter to charge my laptop didnt work and i noticed the spring was missing but didnt think to look in the hole at the time
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Do you know which fuses are for the cig lighter? On driver's side fuse box panel or passenger's side? (In the owner's manual there's 2 fuse boxes, one on each side checked both fuse 7 on driver's side and fuse 11 on passenger's side but they were both fine). Thanks...
gmo7979
12-16-13 11:21 AM
