need help! wheels size for my GS 2006
HI, I FROM RUSSIA, MOSCOW, I want to buy 4 20" wheels & tires for my GS 300 2006, and I have a questions.
1) I want the same tire size for front and rear - 245 35 r20 is it OK? No rubbing?
2) I don't know, what ET do I need? I think 38 for front and rear or 40 for front and rear will be OK? I do not want aggressive look, I just want to have no problem with rubbing!
Thank you, and sorry for my English
Thank you for unswerving my question!
Originally Posted by NorCalGS3
You got it! Those sizes should work...as long as the wheels aren't too wide (9" max in the front to be safe). Good luck.
I asking so many questions because I can't change it and try it on my car - I in Moscow
Dimos,
I am running Iforged Trials 245/35/20 in the front and it rubs slightly on hard turns. This is a tough one because I know that other members have the same size and say that they have no problem with it rubbing. I would suggest that you PM G2 Autosport, he has all the right info.
Good luck.
Good luck.
