Changing running lights and fog lights with blue bulbs?
I would like my running lights and fog lights to be blue-white like zenon. I read one guy put yellow film over his fog lamps to change the color, but I was wondering if the actual bulb can be replaced with a blue-white one? Anyone know the specs of these blubs? Can they just be replaced with different color bulbs?
Black Ten
Black Ten
Originally Posted by costanza
Replace them with Sylvania Silverstar bulbs.
Would the Silverstar's look most uniform with the HID's compared to the "Cool Blue"? Did you replace your DRL and Fog's with the Silverstar's?
Originally Posted by Benzoboi
I have to find the way to get to the DRL's...I changed the high beams out to blue ones...
Originally Posted by 4thone
I thought the high beam and DRL were the same bulb(9005).I put siverstars in and the DRLs are still yellow.I did have success with the small running lights switched to LEDs in a blue tint.
if so...
what bulbs and where did you get them to replace them
Where did you get the LED's with blue tint?
Originally Posted by mkim1120
running lights meaning the ones under the seats?
if so...
if so...
Originally Posted by HotShotEng
Correct me if I'm wrong, but I think the reason the DRLs look yellow is they are running at a lower voltage than the bulb is rated at. This allows for longer bulb life.
The Sylvania Silverstar bulbs is an option but I am looking at others to find the right colors for me.
Take a look at some of the bulbs\LED's from this site.
http://www.autodynamic.com/
If you guys have other sites to look at please post threads as well.
the yellow color is like blah
would like to change it
how difficult is it to reach down there and change the DRL>?
is it like any other headlight buld on other cars?
i remember doing this alot in the import racer days
but would have to change out the bulb often which was pretty annoying
if so...
if so...
I call these the running lights or parking lights.They come on when your main lights are on or when your parking lights are on.I think the bulb is a 194.I replaced wiht a small LED.
Heres a pic.
