GS460 no go, engine doesn't fit...
#76
This is all good news...
Originally Posted by magneto112
There is a big power difference between the 350 and 460. Plus I believe the GS has a wieght advantage over most of its competitors as well(besides the 5-series). I'm thinking of a 5 sec flat run with 4.8sec at best.
I believe the new 550i's are around 5.2 sec or so....
EDIT: actually it does have a weight advantage....as little as a 100lbs to around 250+.
#77
Phat Monkey
Originally Posted by Rockville
and now there is a timeframe next Spring for the GS460, It should have low 5's in the 0-60 sprint. The GS350 should be in the 5.8 sec. range. RWD. I am so relieved that we are finally hearing about the GS460 in the press.
I think the GS350 is around 5.5s, while the BMW 550i is 5.4s. I don't know how fast the GS460 will be, but it better be around the low 5s or high 4s...heh ...Oh well I will just wait for my GS450h...
#78
Guest
Posts: n/a
Originally Posted by 1SICKLEX
Its not like have put the new engine in the 3GS but it will fit. It will probably fit the IS too.
Closed, GS 460 is confirmed
