Tire rotation method
What's the correct procedure when rotating tires? The manual mentions that the rear tires should be moved straight to the front while the front tires should be moved to the back diagonally. However, when I was watching the service guy at the dealer do it today for my 5k service, he just moved the rear tires straight to the front and the front tires straight to the back (not diagonally as per the manual). Does this matter? Should I bring it to their attention?
As documented in the manual is the correct method. Front crossed to the rear, rear straight up to front. Lugs torqued to 76 Ft LBs.
Does it matter, yes it does if you want maximum milage out of the tire set.
The service guy is betting you don't have the time to return it to have it corrected, meaning reversing the two rear tires. You're not a AWD or Four wheel drive..
I don’t know what kind of tires Lexus is putting on the GS now, but tire rotation is based on the type of tires you have. The above diagram would be correct for non directional tires. However, if you have directional tires, then rotation is left front to left back and right front to right back. Now for me, I don’t worry about rotation since I have a staggered setup with directional tires although technically I could rotate them but it would involve removing the tires from the rims and flipping them.
Originally Posted by rominl
yeah that's what i was thinking. do you have directional tires? i thought most gs come with directional tires rather than non-directional or assymetric. is it's directional, then you can only do front and back, you can't cross swap
http://www.tirerack.com/tires/tires....ero+Nero+M%26S
it's asymmetric design. that means you can put it left and right no problem. in that case i think he should have cross swapped.
now i wonder if the stock tires are directional? if so, maybe he thought you still have stock tires?
So I called them up today and mentioned what happened when the rotated my tires last time and they said they always rotate from front to back and back to front without crossing. I did a bit of googling and found this article on Edmunds:
http://www.edmunds.com/ownership/tir...5/article.html
Here's a snippet:
Rotating generally does not refer to either of the following actions:
Exchanging tires on the same axle -- for example, swapping the rear tires left to right
Criss-crossing tires -- moving a tire from the passenger's side rear to the driver's side front
There's a good reason for this. Tires develop wear patterns as they age. Some of these patterns are tied to the suspension system and the alignment. That's why we keep the tires on the same side of the car.
I've decided to just leave it alone.
Here's a snippet:
tsiripong
04-27-18 06:16 PM
K-Bud
GX - 1st Gen (2003-2009)
02-18-08 06:24 AM
