New wheels and Tire Pressure Sensor
Old 04-18-06 | 05:57 PM
FlintGS06's Avatar
FlintGS06
Originally Posted by FlintGS06
my light took 3 days to come on after having the sensors removed while switching wheels
My light is now off after about another week.
Old 04-18-06 | 06:43 PM
GSKING430's Avatar
GSKING430
20 inch Lowenharts was told sensor wont go in the 30 series tire. My dealer restes the light in the dash. Never had stock wheels on. Car has 6k miles. Sensor light comes back on around every 2k miles
Old 04-19-06 | 07:55 AM
nardeezy's Avatar
nardeezy
My 20" iforged wheels should be installed this weekend. I have an extra set of tire sensors that I am going to put on the iforged. My installer explained to me why the sensors won't fit on a multi piece wheel. The valve stem hole is not angled like a one piece wheel, it's at a right angle. He said there is a kit that can strap the sensor on and from what he told me it's pretty reliable and he's done it on other cars.
Old 04-19-06 | 08:05 AM
nardeezy's Avatar
nardeezy
After doing more research on this site I don't think I want to install the sensors with a strap. It makes sense, with all of the vibration from the road and everything else it is bound to come loose or move around unless it was bonded with a specific loctite or actually bolted.
Old 04-19-06 | 09:49 AM
Eternity3G's Avatar
Eternity3G
CL Folding 100000
My light finally came on (after 1K miles) but it goes away periodically... from my past experience playing with sensors, the drilling is the best option, but DO NOT under any circumstances let an unexperienced shop do it.... I can't drill my wheels since they are loaners from a friend so I'll just live with it for the time being...
Old 04-19-06 | 02:37 PM
nardeezy's Avatar
nardeezy
I actually seen the stainless steel straps. They are used on aftermarket tire pressure sensor kits for RV's and motorcycles. The strapping method must be durable
Old 04-21-06 | 11:23 PM
nardeezy's Avatar
nardeezy
I lucked out! My new iforged 2 piece wheels are designed to work with OEM tire sensors without the strap. The valve stem hole is on an angled fillet (similar to one piece wheels). I bought the tire sensors for $84/ea and the mounting hardware for $8.50/ea from Magnussen Lexus of Fremont (with 15% off coupon). That's actually a good price considering that i was quoted between $110 - $220. All need is the sensors to be registered.
Old 05-08-06 | 12:31 PM
vboyz's Avatar
vboyz
which is the best method to deal with tires sensor drill or trap...?
Old 05-08-06 | 02:07 PM
nardeezy's Avatar
nardeezy
1. If they're custom made to the specific car hopefully they tailor the rims for the sensors
2. I would assume using the strap because I've seen RV and motorcycle applications where they use the strap for aftermarket TPMS on stock wheels.
Old 05-09-06 | 09:31 AM
Eternity3G's Avatar
Eternity3G
CL Folding 100000
I still like the drill method... peace of mind and never had 1 leak...ever...
Old 12-02-07 | 08:05 PM
GMTLgs350's Avatar
GMTLgs350
I also had the same problem but, do you remember if you ever did set up the tire pressure monitor system, if you dont then light will never come on even if you have the factory wheels on. For you guys trying to disable the monitor system, sorry out of gas.
vesnyder
ES - 6th Gen (2013-2018)
05-27-19 01:00 PM
mcamson
03-28-16 04:42 AM
LorizRX350
06-19-07 10:02 AM
mikeo
Wheels, Tires & Brakes Forum
12-01-04 10:29 PM
NKalasho
07-04-04 05:49 AM
