Default??????????????????
I think it goes back to what you left it at before you turned the car off. So say, you left the "Map" screen on, turned off the car. Get back in the car, start the ignition, and after you hit "I Agree", it should go back to the map screen.
Unless you're talking about the transition setting... you can go to Menu --> Screen --> and turn off the transition setting.
Any time you shift into Drive, the screen will revert back to the map. If you turn off the transitions, the screen will stay where you put it for as long as you're in drive.
This is definitely one item I wish they would have done differently. I typically like to have the audio screen on. When I stop the car and get in the next time I really don't feel the need to have the map screen up. Why not just come back on where I left it? Another annoyance is any time the Park Assist warning kicks in, it returns me to the map screen instead of where I was previously. There are other times it happens that I can't think of right now.
Of course, these are minor things, but it would be nice to see them come out with a patch or something to stop the annoying return to the map screen after so many event occurrences.
quepasafra
03-23-24 10:52 AM
