Tips, Tricks, DIY's, & How-To's
#574
Hi - I have a 2007 ES 350 that I recently purchased from a dealer as a certified pre-owned vehicle. The navigation has the 5.1 map DVD and I can't get the sequence to work to get into the service menu to override. Since I have the 5.1 map disc, this should work without making a hybrid disc, correct?
#575
I recently experienced a minor problem, but it's irritating. When sitting at a stop light, the rear view mirror vibrates, as in the view behind me is shaking. The mirror is loose when I handle it, but I can't find a screw to tighten it. The screws in the obvious holes are tight. Any suggestions (not critical enough to take it to the dealer (yet).
Thanks.
Thanks.
#580
I have a 2007 GS450h
Can I make a setup, to close all the doors after start rolling with my car???
I had an IS220d while mine was on oil change as a change and it closed the door after I started....
thanks!!!
thanks!!!
#582
Thanks, I'll look for this setting!!
#583
I cannot find anything in the menu.... Where is the "personal preference setting"?? I have a 2007 GS450h, but nothing like that in the computer....
#585
I just put on a new set of wheels and tires on my 07 GS350, but I couldn't find the button for initialize warning system and the "MAIN & 2nd". The manual book indicates initialize warnign system is underneath the steering wheel..."NOPE" "MAIN & 2nd" in glove dept....NOPE"?!?!?! Does anybody know how to reset these two?
thanks.
thanks.
