Tips, Tricks, DIY's, & How-To's
Old 06-12-06, 03:50 PM
  #76
Eternity3G
Eternity3G's Avatar
Originally Posted by Valet Park
Ok, just tried it again and nothing, I must be very slow. What about this, when I select the Odometer, you have to push it once more to hold ten seconds then the display changes to Trip A.
Or should I select ODO and hold? Im going to try that and see if that works.
when i did mine, it was on "odo" and changed to "trip a" during the hold...
Old 06-12-06, 04:01 PM
  #77
Valet Park
Valet Park's Avatar
Well then I don't know wtf im doing wrong then...
EDIT: Finally!!!! It's soo hot out there I figured I could do it with the windows down, but the windows mustbe up! I then tried to do it for the passenger side too but couldnt get that one, another day when I need some frustration Ill try it .
Thanks for the Help Eternity
Old 06-15-06, 09:17 AM
  #78
Eternity3G
Eternity3G's Avatar
Default Install TPMS sensors onto new wheels... (Pro's Only)
1) Mark the spot where you'd like to open the hole to install the sensor. You want to find a spot with similar curvitures as the stock wheel for best fitment. We are essentially installing a secondary valvestem. (remember you need the entire stem adn sensor unit from factory wheel)
2) Start with a small bit and drill a pilot hole.
3) Use a larger bits to open the hole just enough for the sensor to go through. Or to make life easier, use a uni-bit. I forget the hole/bit size... sorry guys...
4) Attach sensor and stem...
5) Try to position the new stem opposite the "actual" stem for better balance. You won't have to utilise as many weight when balancing the wheel.
6) Here's a view of the sensor from the other side after the tires been mounted...
jtwong007 (05-22-23)
Old 06-15-06, 11:22 AM
  #79
Bold
Bold's Avatar
Originally Posted by Eternity3G
1) Press "Menu" button
2) Press "Volume" on the Nav Screen"
3) Press the "speaker" picture on the top left screen
4) Press the bottom left corner of the screen (it's blank, nothing there)
5) Repeat steps 3 & 4
6) A screen should now Appear w/ several functions
7) Find the "Override" button and hold until you hear a "beep"
8) The Override button letters should now be in black as the others are white
9) Press the Back button and you are ready to go!
*** Keep in mind this feature is required to be done everytime you start the vehicle. It will not retain this in memory ***
I tried this one several times and it didn’t work? any advice?
Old 06-15-06, 11:26 AM
  #80
Eternity3G
Eternity3G's Avatar
I don't get it.. handful of ppl complainig of this... If you know someone that has another GS, prius or land cruiser.. try it on theirs... i dunno...
Old 06-15-06, 11:42 AM
  #81
SGT
SGT's Avatar
Where are you from? Maybe it's different on international models.
Old 06-16-06, 01:51 PM
  #82
Bold
Bold's Avatar
Yes it's not a US version, I'm leaving in the middle east , United Arab Emirates ,and there is many different like the DVD and radar sensor but the on with the info button worked with me, actually I should say is there any way the local dealer can disable such things in the car? and how can I work it out? cuz this phone thing is really annoying me.
Old 06-17-06, 03:53 AM
  #83
mj0723
mj0723's Avatar
The Navi by-pass tricks works on my wife's 3GS, on my friend's land-cruiser and the new RX350 that I got to drive for 2 days as a loaner. However, these are all US-version Lexus vehicles.
Maybe foreign model of 3GS is a bit different?? hmmmm.......
Old 06-19-06, 10:18 AM
  #84
szilu
szilu's Avatar
well, as all other mods are working (bluetooth volume, seatbelt) it seems to be something else. However mine was built for and sold in Europe, so.... Do you think that the gen4 nav will work with gen5 maps? or we have to make it without map updates from now on?
Old 06-20-06, 02:00 PM
  #85
gmeardi
gmeardi's Avatar
Unhappy
Originally Posted by SGT
(...) NAV override hack not working (...) Where are you from? Maybe it's different on international models.
Personally I've the same problem: tried in many ways and combinations, but... no override menu ever shown.
And I've got an IS 220d, bought in Italy. Thanks for any advice. Ciao
Old 06-27-06, 11:39 AM
  #86
Eternity3G
Eternity3G's Avatar
NP... nice to no that windows need to be up... woulda never thought of that!
Xenith (02-10-21)
Old 06-28-06, 08:27 PM
  #87
4thone
4thone's Avatar
Default TPMS sensor
This year when I installed my wheels and tires I disconected the battery .I reconected it after 30 minutes or so.I have not had the flashing light that botherd the hell out of me last summer.I am not sure if this is a fix or a fluke.
Old 06-29-06, 11:23 AM
  #88
Eternity3G
Eternity3G's Avatar
Eventually over time (especially on long drives over an hour) the check light will come back.. but you can just turn around and shut it off again!
Old 07-01-06, 12:25 PM
  #89
snak
snak's Avatar
Default Oil Maint Reqd - can't get Odo to blank
I've just had an oil change on my 2006 GS300, and the Oil Maint Reqd indicator is still on. Have tried the procedure per the manual and this forum, but can't get the Odo button to get me to a blank screen.
Thanks in advance for any suggestions.
Old 07-01-06, 03:57 PM
  #90
flipside909
Lexus Connoisseur
flipside909's Avatar
Are you trying to do the reset under ODO mode, not Trip A or B? You many want to recheck that just in case.
Quick Reply: Tips, Tricks, DIY's, & How-To's
