Official numbers on GS 350
Super Moderator
Originally Posted by CrazyMPG
should it have the same hp as the IS350? or is it actually more? ![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I posted the above just to illustrate that the GS350 hp & torque should be very close to that of the IS350.
The following is from lexus.jp for the IS350 in Japan :
Once it it released in Sept, How long do you guys figure it will take for the GS350 to cool off enough for deep discounting, 6months-1year?
Guest
Posts: n/a
performance should be around the same for the GS350 and IS350 right? or will one be faster, better, etc... ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
They did not post GS 460 estimates.
Super Moderator
Originally Posted by 1SICKLEX
I think either Magneto or Lexarrao posted a Lexus press release stating that GS 350 time are basically IDENTICAL to current GS 430 times.
The fastest 0-60 time for the GS430 from any source is 5.7 sec., while some sources got 5.1, 5.2 sec. 0-60 for the IS350. I really expect the GS350 to perform slightly better than the GS430 . . .
As for the press release you mentioned, I don't really remember exactly, but maybe it's 0-100 kmph(=0-62 mph) in about 5.7 sec. ?
Originally Posted by jlin101
GS350 may have a few more ponies, but IS350 has a big weight advantage. Lexus quotes GS350's 0-60 number about the same as GS430, at 5.8 (compared to IS350's 5.3). If GS350 gets low 5's, then GS460 would be expected to be <5s, which is unrealistic.
