Just test drove the 450h and is350
Old 07-04-06, 12:43 PM
spwolf
spwolf's Avatar
Originally Posted by CrazyMPG
So if you add coilovers to the GS450h that has the Active Stabilizer Suspension System...there shouldn't be any problems with the system messing up?... ...would be cool if that's all that is needed...
well, I would think not... They are active stabilizators, which really should not to much with suspension...
But do you really need coilovers for GS450h with ****?
Old 07-05-06, 12:37 AM
swisslexusclub
swisslexusclub's Avatar
That's a good point. I'll get my GSh in a few days and it has AVS (Active Suspensions are not offered in Switzerland).
Can I use the GS300/430 lowering springs in the GSh with AVS?
Old 07-05-06, 12:04 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
I am still confused about the ****...it doesn't lower or raise the height of the car right?...so if you want to lower the car...what is best...springs or coilovers?
Old 07-05-06, 01:34 PM
4TehNguyen
4TehNguyen's Avatar
in terms of range of adjustability and how precise you want to be lowered, coilovers are the best. Unlike springs you can get dead even drops on all 4 corners on the car with coilovers
Old 07-06-06, 05:46 AM
Nikker1985
Nikker1985's Avatar
Exclamation Big Important Questin about GSh performance!!!
I ve seen two numbers. One of them is 5.2 seconds for 0-60m/h and other is 5.9 seconds for 0-100km/h aka 62m/h. Now, why do you suppose that is? Is it maybe because European version is different from the American? Are they lying due to some kind of tax law? The IS350 is not out yet so there is no way to compare them. Hybrid technology is great, I am an RX400h owner and love that cars performance and luxury but if GS needs 5.9 seconds, I d choose IS350.
So how much did it take you to reach 0-60 with your GS and is there a difference between EuroGS and USAGS?
Old 07-06-06, 09:46 AM
jwa
jwa's Avatar
If the GS 450H is slower in the Euro version, what makes you think the Euro IS 350 won't also be slower? It seems that the engines of both will have to be tuned differently than the US version to meet emmisions and gas requirements. I haven't seen any test data that suggest the IS 350 is quicker than the GS 450H in the US version, and I don't think the results will be different in Europe.
Old 07-06-06, 10:42 AM
Gojirra99
Super Moderator
Gojirra99's Avatar
Also, tests done on exactly the same car from different sources can differ significantly due to factors such as temperature, altitude/air pressure & how aggressive the testers were etc. . . . . . .
Old 07-08-06, 03:16 AM
Nikker1985
Nikker1985's Avatar
Unhappy Indeed!
But there is a huge difference between 5.2 and 5.9. And if the euro version is slower, that sucks!
Maybe you can tune it likethe USA version. I am thinking that there probably has to be an extra catalyst. (The thingy that prevents harmfull gasses from being emited).
Old 07-08-06, 02:05 PM
spwolf
spwolf's Avatar
there are absolutly no differences in engine. 5.9 is Lexus suggested number for GS450h for the UK, for 0-62 performance, while 0-60 in the USA is suggested as 5.2.
I think one of the mags tested it at 5.3 which sounds right.
Old 07-08-06, 05:17 PM
rominl
exclusive matchup
rominl's Avatar
honeslty, i wouldn't pay that much attention to the speed difference from different magazines, etc... they have different drivers, conditions, elevations, etc... who knows what are the variables. most of the time i care more about comparisons between different cars in a comparison test which are usually done on the same day at the same location
oh and btw, even with ****, i would still put on coilovers to lower the car
Old 07-08-06, 08:23 PM
Received 2,424 Likes on 1,588 Posts
**** has to be one of the most unfortunate car acronyms I've seen.
Maybe it could be used in advertising though... "We kick ****"
Old 07-09-06, 02:37 AM
swisslexusclub
That's right. The Euro GS450h doesn't differ from the US version in terms of the engine performance. It's the 2 m/h that causes the difference of 0.7 sec. in acceleration.
Anyhow, this post seems to get a bit off topic.
Old 07-10-06, 09:17 AM
spwolf
spwolf's Avatar
yep. Different Lexus distributers give different estimated performance numbers. What is important is the magazine tested numbers, which are pretty good.
DickH
Suspension and Brakes
02-08-17 10:46 AM
mlinn1967
08-09-16 05:02 AM
GreyHound
01-01-07 07:55 PM
mike714
02-14-06 10:26 PM
pinoychris
01-24-06 07:46 AM
Quick Reply: Just test drove the 450h and is350
