Fuel Requirements for '06 GS300 AWD
Does the Owners Manual for the above car mention anything about using 87 octane fuel(Regular grade)? I know that other model Lexus's say that you can use regular with slightly reduced performance. I was wondering whether this holds true for the GS's also. Thank you.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Originally Posted by GS4fun
I do not believe you can use regular.....i have always used premium and I think that is what is required.
granted though, i don't see any reason why you want to use 87. it's not like 91 is a lot more expensive
Try this experiment:
Use 91 for 2 tanks. Drive normal and figure out the average MPG.
Use 87 for 2 tanks. Drive normal and figure out the average MPG.
Now, If you take the MPG from using the 87 and compare it to the MPG when using 91, you should find (as I did, as well as a few others) that there is marked difference. Take the MPG and divide by the cost per gallon to figure the cost per mile. You will find that cost per mile of 87 oct offsets the increased cost per gallon of 91 oct.
Bottom line. Use 91. I am going to make the assumption that you are asking just for the sake of knowing..But if not...If can afford the car but not the gas you got BIG problems.
pierpark
GX - 2nd Gen (2010-2023)
553
12-12-23 07:12 AM
Iansaltes
07-14-08 04:14 PM
movaaa55
05-01-08 03:06 PM
