I'm not sure but if it's like any other light housing, the only way to take it apart would be to take it out and bake it (or heat gun it) to loosen the adhesive, which I wouldn't recommend as it almost always screws up the plastic. You're better off just trying to clean it from there. Good luck.
Those LED bulbs tend to be quite blue. Is it bluish white or just straight up blue?
Yeah, when I have the time, I'll try to just stick in a wire covered in an alcohol-soaked paper towel.
The LED bulbs I saw from others on this forum seemed very blueish, but the ones I'm getting are pure white. They actually look a little more white than my HID headlights.
what bulbs did you purchase and from where? I myself am looking for a wedge bulb that will match the gs3 hids as close as possible, I changed my fogs out to the cool clue bulbs and they look perfect but now am trying to find the best wedge bulb
I got the 12-LED wedge base bulb from Super Bright LEDS. I'll let you know how they look when I install them after I get them back.
But the W12 will be a little bit too big. if you go with this one you will need use electric type to secure it. you can go for w6 or w5 they will fit perfectly.
