Dropped GS300 AWD....
Thanks for the compliment, the sevas wheels look great for the money these are the third set I've ordered in the least 2 months. As for the rubbing, i don't really have any issues we trimmed the rear fender liner and heated the front fender shrouds. I had a minor noise when I had four (large) people in the car, but that was when i hit a big dip in the road.
Nardeezy, for you to heat the front fender liners all you need is a heat gun and heat up the parts where you see the tire rubbing. Most of the time if there is rubbing in the front it will leave a mark on the shroud, so heat it up and then push the plastic in when it gets soft. As for the rear i trimmed the metal inside the wheel well. You have to take off the trim guard around the fender and try using an airsaw so you are able to cut a clean line.
On my old school Integra I just removed the entire lining. I didn't want to do that to my Lexus. As for the rear, the rubbing is not too bad so I'll just leave it alone.
Hi guys I've been away for a while.Busy working without much time to play on the comp(my summers are short).Back to the subject.My car also has a slight vibe when accelerating from a stop or very low speeds.I haven't noticed any vibe while crusing.My wheel and tire setup are all equal so I am assuming the AWD is the cause of this.
with this vibe talk
Jmags
01-12-11 12:06 PM
