Need a lil help with the next mod: Sound System
Old 11-11-06 | 06:53 PM
NAZTY97's Avatar
NAZTY97
Default Need a lil help with the next mod: Sound System
Ok, here it is. I am looking at doing the JL Audio Cleansweep, a Rockford Fosgate T8004 amp for the mids / hi's and T10001bd for the subs. I'm thinkin' to JL Audio 10W3v3-8 Subs.
What I need to know is the size of the dash speakers, and the door speakers. I'm assuming the door speakers are 6 1/2" coaxials. I'm not sure what the set up is on the dash board.
Anyone know??? Once I determine this, this mod should occur in a week or two.
Old 11-11-06 | 07:03 PM
Franknyc30's Avatar
Franknyc30
did you check crutchfield.com "what fits my car"
Old 11-12-06 | 12:41 AM
nardeezy's Avatar
nardeezy
If you can afford a Lexus GS why not purchase high fidelity audio equipment to replace the OEM components. Example, McIntosh, Xtant, Dynaudio, MB Quart, etc.? For subs, JL Audio is good. When I was into high fidelity car audio systems these were the big names.
Old 11-12-06 | 07:57 AM
NAZTY97's Avatar
NAZTY97
Rockford Fosgate owned MB Quart for one, and there are other good brands out there.... I am looking for size fitments, so I can determine what brand speakers I want to go with based on application. The Power Series Rockford amps are actually pretty dope,... there is always better / more expensive,... for me it's about finding the balance of cost / feature / quaility. $900 amps are by no means HIGH END, but a long ways from LOW END.
I am replacing everything in the car minus the head unit obviously due to the touch screen.
Crutchfield has not always been overly accurate with their fitment matrix.
** just checked crutchfield, and as I suspected,...they have not researched this vehicle yet **
Old 11-12-06 | 08:08 AM
Nauticalx's Avatar
Nauticalx
I would tear it down to get the sizes..that way you are 100% sure...you can add to the forum for others...and you'll be that much more familiar with the teardown once you get the goodies to replace em
Old 11-12-06 | 06:32 PM
HotShotEng's Avatar
HotShotEng
Smile
Check out this website it has the specs on the speakers: http://www.marklevinsonlexus.com/overview.asp?model=gs (click on each yellow dot for speaker info)
Good luck on your mod
Old 11-13-06 | 12:30 AM
NAZTY97's Avatar
NAZTY97
Appreciate that sir! I'm on it.
Old 11-13-06 | 06:42 AM
IS_250's Avatar
IS_250
if you're planning to replace all the speakers and use seperate amps consider using something like the Audiocontrol LC8. I was considering doing the same in my IS if did a complete system.
Old 11-13-06 | 11:26 AM
Franknyc30's Avatar
Franknyc30
NAZTY - keep us updated and takes lots of photos. dont forget to include cost/time to complete. thanks
Old 11-13-06 | 11:27 AM
Franknyc30's Avatar
Franknyc30
PS - sound quality compared to stock would be nice
Old 11-13-06 | 01:20 PM
NAZTY97's Avatar
NAZTY97
right now i'm evaluating which line out converter is going to be the better choice.
I've narrowed it down the JL Audio Cleansweep, and the Audiocontrol LC-8.
Just a few other minor details to work out... I'm not gonna do the labor.... gonna pay one of my peeps custom shops to do a custom enclosure and amp rack to minimize wasting the trunk.
Old 11-13-06 | 02:21 PM
nardeezy's Avatar
nardeezy
Fair enough, if you're not confident on your sources for speaker specifications you can always contact Lexus technical services http://techinfo.toyota.com. I have used this source to find out very useful suspension data.
Old 11-14-06 | 06:15 AM
IS_250's Avatar
IS_250
from what i recall, the Cleansweep only has 2 outputs. you'd probably be better off using the LC-8 unless you want to defeat the factory eq settings, which the cleansweep does. so far ive seen someone use just an LC-8 or an LC-8 + cleansweep.
Old 11-21-06 | 08:40 AM
2JZLexIS's Avatar
2JZLexIS
If I were you, i would go JL Audio all the way! I know it may be a little more expensive, but you would be paying a bit more for a lot more quality. If you like to fine tune your system and not just turn up the bass or the highs, you would regret not buying JL Audio. When you hear a car with a Jl Audio system, you will understand. So if you ask me i would tell you to get evreything from subwoofer to door speakers to amplifiers, all Jl Audio!
Old 11-21-06 | 09:40 AM
dandd2's Avatar
dandd2
custom car stereo did that surgery on my car so i could watch dvd in drive
they seem pretty knowledgeable and also that place off richmond..e wire or is it live wire?
they do some extreme custom work
lots of texans football players take their cars to get done on their car
check them out they have alot of high end insanely custom stereo cars outside just relaxin on the pavement
