Question for you wheel experts
Hi all,
I have a 2007 GS450h with factory 18" wheels + summer tires. I am starting to search for a winter tires now. My situation is that I currently have a spare set of 18" wheels from a 04 RX330. Here are the dimensions:
07 GS450h:
18 x 8 +45 offset (the size are from 06 GS430 18", i assume it's the same)
04 RX330
18 x 7 +35 offset
Would it be possible I can buy a set of winter tires and mounted them on the RX330 wheels and put on my GS450h as winter tires?
Thanks in advance for any the inputs!!
07 GS450h:
04 RX330
18 x 7 +35 offset
It might work, it's going to be trial and error. Is there a tire on that RX wheel? If so, mount it on your 450 and see what it looks like. Else, it will be hit or miss. If I were you I would try to find a low cost set of new or used GS300 wheels.
Nope, the RX rims I have has no tires on them. I know for a fact that the factory tires size for GS450 is 245/40-18, and I am thinking of going for 235/40-18 winter tires on the RX rims then put on my GS. Do you think it might work?
ok, i dont own any gs' so i cannot verify accurately. but it looks like you should.
Calculations:
18*8 +45 is close to 6" backspacing and more than 2" front spacing (approx 2" and 5mm or ~2.25").
18*7 +35 is close to 5" backspacing and more than 2" front spacing(approx 2" and 2.5mm or ~2.1").
so, if anything, more than likely you are just simply getting an 1" worth of extra space between your suspension and tire distance.
Conclusion:yes.
Charley
Calculations:
Conclusion:yes.
Charley
18*8 +45 is close to 6" backspacing and more than 2" front spacing.
18*7 +35 is close to 5" backspacing and more than 2" front spacing.
Conclusion:yes.
Charley
Conclusion:yes.
Charley
