VIAS Install '3rd Gen GS Edition'
#31
True. And it looks nicer on the screen. And the more I use my screen, the more I quit thinking this was a error in buying this car. Not saying the car is junk by a long shot, but going in for one car, finding out it didn't fit my needs, then finding another car that just barely fit my budget, and I always wanted a GS, I was pulled into getting one.
I'm sure if I test drove the G35 again right after that car, I might not have bought it. It would've been almost $9k cheaper and have voice recognition for most stuff like a/c,radio,etc. Granted some say it sucks, but it had it. Also a working Navigation.
The main thing I know I like about the GS is that it FEELS upperclass. Everything seem to have a nicer finish (except for that funny rubberized dash and door material) And it could've use a bit more wood.
Sorry went off topic. Anyways, it just means on the ipod I need to make special playlists. Btw, can I just tell the SLI to play all songs on the unit? Maybe I'll just buy a Ipod nano 8gb and dump all my good songs to it, and thats that.
#33
Ok, is everyone here saying you can't use the existing iPod folder structure (e.g., music/genre/artist/album)to find and play music? If that's the case, I'm not sure I want this version of the SLI. I mean come on. Why wouldn't the unit have the software smarts to find and play files using the existing iPod structure? This is just software, right?
Can anyone shed some light on this (if true and why the limitation), otherwise I'll post this question over on the VAIS tech forum?
Thanks
Thanks
#34
The main reason for it is that the 3GS head unit wasn't designed with navigating a folder structure in mind. It would require some siginificant re-coding of the headunit to make it useable.
The head unit does understand a CD changer so that is how it talks to the Vaistech. Playlists are disks and tracks are...... tracks.
The only headunit/ipod combo I know of that enables you to view the tracks on the ipod in the same way is the factory fit interface is the 2007 Audi A8.
#36
So how are the rest of you out there with SLI units organizing your music into playlists so you can easily find the music you want to listen to? I'm struggling with how this works when you have thousands of songs across hundreds of albums and artists.
Today finding music on my ipod is as easy as picking the genre (rock, country, etc.) picking the artist, and then either picking the album or just listening to all the albums by that particular artist. That's the beauty of the iPod... simplicity, form and function (
I'm sure there are many more of you out there who have more music titles (bit over 5,000) than I, so what are you doing?
Thanks
#37
#38
#40
Kuch123 (or others with SLI installed),
I installed my SLI today, and now have it working with my 15GB iPod. It's working in Simple Mode only, so I believe I'm going to have to splurge for a newer iPod if I want full integration. I do however have a few questions after install.
1) When I went to program the SLI, it says in the instructions that you'll hear some beeps to let you know when its done. I'm not hearing any beeps at all, but the programming sequence seems to work. Does anyone know where the beep sounds are suppose to come from, e.g., the SLI unit, over the car stereo speakers or from some other chime like the seat belt chime? I've got the seat belt chime turned off on my GS, so I don't know if that's impeding the sounds. Anyone out there with thoughts/ideas on what's wrong with the beep sound not working?
2) Also, anybody change the speed setting on the SLI unit? I tried it to see if that would get my older iPod unit to work in full mode, but because I couldn't hear the beeps from the programming sequence, I wasn't sure if I programmed it right
Thanks for any help you can provide.
#41
I have the seatbelt chime off but the programming sound seemed to come from the "car" not the sli unit at all....same place where your seatbelt makes a sound when you first turn on the car...
Also when I first tried to program the unit, i heard one small beep and a long beep, manual said several so I tried it again and then it did 2 short beeps and long beep. I am upset that the unit does not show folder names at all unless you press "disc title" or whatever....Otherwise all you see is discs but no names....
#42
About organizing playlists... why not just organize under genres and if more than 99 in a genre just do 'rap1', 'rap2' or whatever.
99 songs at 3 minutes each is nearly 5 hours. How much driving do you guys do!?
#43
Fitted mine on Saturday. Thanks for the guide. It made taking the trim apart in the car so much easier although I had to mirror some of the things as my car (UK) is the other way round.
I also did the DVD/BT bypass and added a switch to toggle the VSS in to the navigation so I can enter addresses while moving.
Thanks to all on this site that provided the information to enable me to do these things.
#44
Hey Kuch123: Are you able to use the TRACK UP/DOWN and DISC UP/DOWN feature on the nav itself (dedicated buttons next to the casette adapter)?
thx
**EDIT**
Kush123: I dont know how the hell u got that vaistech box in there,but i've tried 5 times and it just doesn't sit well ther e(unable to properly get the left panel to close properly-i dont want to force it).
I may go the other route and mount that sucker on top of the tire pressure monitor -- any other suggestions (location wise)?
thx
**EDIT**
