Road and Track Magazine - Long Term Road Test GS 450H
Old 01-05-07, 04:18 PM
PHML
Master Thread Closer!!
PHML's Avatar
Default Road and Track Magazine - Long Term Road Test GS 450H
I thought this was interesting.....
2007 Lexus GS 450h
Effortless performance and the luxury we’ve come to expect from Lexus make this hybrid quite popular...but pack light.
By Shaun Bailey, Road Test Editor
February 2007
In our July 2005 issue we compared a BMW 550i with a hybrid-powered Lexus GS, the 450h. To our surprise the 450h could almost match strides with the 6-speed-manual-transmission-equipped 550i. Quite impressive for a car that scores EPA fuel economy ratings of 25 mpg city and 28 mpg highway. In the test we noted a fundamental difference in character between the cars. The BMW 550i was a supreme sports sedan; the GS 450h was just a supreme sedan. The Lexus gives up most of its handling prowess in favor of a comfortable and well isolated ride. Not a bad thing, just not what might be expected of such a quick car. As the most powerful hybrid available, and featuring a 2-speed continuously variable transmission, the GS 450h needed to be tested over the long term, even if it’s not the most sporting sedan. We also wanted to see if the fuel mileage over 50,000 miles would be better than the poor result (18.7 mpg) we recorded during our previous hard-driving comparison test (July 2006).
We’ve had the car for just about two months and it’s clearly popular. It’s away from the office more than it’s here. And it’s accruing the equivalent mileage of a roundtrip Los Angeles to New York drive each month. In the process, it’s averaged about 26 mpg. Not bad, and about what we’d expect for the type of highway driving it’s been doing. This car’s forte is local trips in traffic, where the hybrid system can be best put to use. For long drives the car is clearly capable, but there are some obvious limitations. First and foremost is its trunk size. The Lexus can carry four people, but not all their luggage. Half the trunk is occupied by the battery pack, leaving enough space for two good-size cases or a few bags of groceries. There isn’t a pass-through, so no skiing or snowboarding without a rack. In the real world, most times it will be one or two people in the car, thus leaving the rear seats available for cargo. However, we feel that a $60,310 car should have a larger trunk for safer storage of luggage.
The base GS 450h has a Manufacturer’s Suggested Retail Price of $54,900. Standard equipment is quite good, with all the usual luxury-car amenities. Some particularly welcomed features that aren’t typically standard are heated and cooled leather power-assisted seats, keyless entry and starting, driver and front passenger knee airbags, variable power steering ratio, adjustable ride comfort and adaptive front headlights — the type that point where you turn. On top of that, we opted for the $480 tire upgrade of Dunlop SP Sport 5000 run-flats with spare, $1900 voice-activated navigation with Bluetooth connectivity, $1780 Mark Levinson audio system, $486 XM Satellite radio kit and a $69 trunk mat.
Driving the GS 450h isn’t difficult. Most everything is intuitive, even the power button that replaces a conventional key. Our familiarity with the Toyota Prius has helped us understand the car. New drivers will likely have to familiarize themselves with a few details.
The start button is actually a power button and says power “on/off,” not the more conventional “start/stop.” The trunk and gas-flap release, along with the mirror adjustments, rear sunshade and a few other buttons, are well hidden. They reside grouped together on a hidden panel next to the driver’s left knee. It pops out easily enough, but we do it an awful lot and we wonder when the mechanism will wear out. Before backing out of a parking spot, the car must be turned on, excuse me, I mean powered-up. Step on the brake pedal and hit the glowing button on the dash. Nothing happens, but a light in the gauge cluster appears saying “READY.” This means if you put it in Reverse and take your foot off the brake, it will move — even if the engine isn’t running. Typical of hybrids, it takes first-time drivers a little while to get used to. Turning the car off is a little confusing as well. If you pull into a spot and the engine shuts off, you might be fooled into thinking you’ve shut the car down and can hop out. Don’t. The car will drive away under electric power. The driver has to put it in Park and hit the off-button before the system will shut down. Confusing? Not really; it’s just a new technology we have to get used to.
The same applies to the lack of shifting that goes on when driving. The drive system of the hybrid approximates the functionality of a continuously variable transmission. Put the throttle to the floor, and the 3.5-liter 24-valve V-6 with direct injection jumps to an optimum rpm. Then it stays there, while dual permanent magnet electric motors sort out the gear ratios necessary and also assist the 339-peak horsepower to the rear wheels. If the batteries are low on charge, there isn’t much assist, but that’s rarely the case, as the system charges itself while cruising and every time the brake pedal is used. Unlike the hybrid system in the Toyota Prius, the GS 450h adds a 2-speed transmission to the electric motor that aids in acceleration. At roughly 60 mph it shifts from low to high, and helps the electric motor provide more forward thrust.
With all this technology, can the Lexus GS 450h meet our expectations of fuel economy and performance? From our initial impressions we think it might. But you’ll have to keep reading to see what’s in store for the GS 450h over the next 37,371 miles.
2007 Lexus GS 450h Specifics
Total Miles 12,629
Miles Since Last Report n/a
Average MPG To Date 25.8
Best MPG (Avg Of 3) 31.5
Worst MPG (Avg Of 3) 21.3
Maintenance costs to date $144
Repair costs to date $0
Delivered Price $60,310
Old 01-06-07, 02:33 PM
Jace7
Jace7's Avatar
very nice article. Gotta love the 450h.
Old 02-10-07, 04:40 PM
AmRov
AmRov's Avatar
Default Nice article
I just put a deposit down on a 450h. I was really impressed with the test drive. I've had 2 BMW 540's, and an X5, and I always loved the V8's. Non-stop power without delay. But the 450h delivers that --and more! I love the bells and whistles and all the luxury. This is a car that takes care of you.
Just to "make sure," we stopped by BMW also today. We were not impressed by the interiors. They haven't changed much since my last BMW (a 2001 X5). Even the $90K M5 can't compare to the 450h in terms of creature comforts. Yes, as a former BMW owner, I understand that BMW doesn't go for that. But I'm at the point in my life where if I'm shelling out around $60K (plus) for a car, I want it all -- speed and comfort.
Old 02-10-07, 06:46 PM
Modeler
Modeler's Avatar
I know exactly how you feel. Two days before picking up my 450h I realized that I could have a 550i costing $15,000 more for the same monthly lease payments because of BMW's high residual costs and low money factors. So I scrambled to the nearest BMW dealership to drive the 550i. While I loved the way it drove, I thought that 450h beat it in pretty much every other category.
I've had my 450h for about three weeks now, and I'm happy with my decision. Except for some really crappy voice recognition, inability to program Navigation while driving, and a few other minor annoyances, the car is great.
Old 02-12-07, 08:16 AM
GreatSmile
GreatSmile's Avatar
Lexus really should let the driver decide if and when to program the nav while driving. All other manufactures do that, why can't Lexus?
But, when comparing Lexus Nav and BMW Nav, I'll still take Lexus Nav!! BMW nav is a joke. You are better off buying a Garmin Nuvi for the bimmer.
flipside909
Hybrid Technology
20
11-21-11 06:49 AM
okc329
Hybrid Technology
02-28-10 09:02 PM
LexFather
05-26-08 05:49 PM
CarMonkey
01-09-07 02:19 PM
XeroK00L
Hybrid Technology
08-15-06 03:22 AM
Quick Reply: Road and Track Magazine - Long Term Road Test GS 450H
