Is there a way to reset engine oil warning light without bring the car to the dealer?
Old 01-08-07, 02:22 PM
ppi_dol_ee
ppi_dol_ee's Avatar
Smile Is there a way to reset engine oil warning light without bring the car to the dealer?
Hello guys.. I brought my 06 GS 300 to the dealer and as I expected it, the bill came out to be $213 for oil change and few other checkup. I wouldnt mind getting check up for 15k or 30k miles but not every oil change... PLease advise how to reset the light after an oil change. or is there a tool i can buy like BMC Rest tool to reset any waring light... thank you
Old 01-08-07, 03:33 PM
HotShotEng
HotShotEng's Avatar
Try this first:
1. With car engine OFF, hold down both the “ODO TRIP” and “RESET” buttons (located in switch box).
2. Continue holding down buttons, while you start the car.
3. Continue holding buttons (approx. 7 secs) until reset occurs.
If first method does not work, try this:
1. Push the “ODO TRIP” switch in the switch box to
change the display to blank.
2. Turn the engine switch off.
3. Turn the engine switch on with the trip meter “RESET”
switch held down.
4. Keep pushing the “RESET” switch for longer than 7
seconds after the engine switch is turned on.
After the above operation, the master warning light comes
on, a warning tone sounds and the above message
appears to inform you that the engine oil maintenance
data has been reset.
Good luck.
Old 01-08-07, 04:19 PM
Jace7
Jace7's Avatar
Originally Posted by HotShotEng
Try this first:
switch held down.
Good luck.
that should work.... Good luck
Old 01-10-07, 12:42 AM
ppi_dol_ee
ppi_dol_ee's Avatar
great... I will try this tomorrow.. thank you very much
Memout
03-03-09 01:09 PM
ASPLS430
07-13-06 07:09 AM
dandd2
11-21-05 09:19 PM
gsdsclark
08-11-04 06:56 PM
chrisgs
Maintenance
11-04-03 07:35 AM
Quick Reply: Is there a way to reset engine oil warning light without bring the car to the dealer?
