the wire cut hack for DVD.
Old 01-29-07, 02:01 PM
Jace7
Jace7's Avatar
so the NAV hack that you do with the wires, is the same as the button push hack for the 5.1 ver? without having to push... this is just available at all times?
oh and Robert, head over my way in CO, to do the hack for me. Just to nerverous to attempt, and I would rather it done shrink wrapped and all.
Let me know when you're heading to do this as a favor to me.
Thanks.
Old 01-29-07, 02:37 PM
lexuslover
MultiTasking Mom
lexuslover's Avatar
yes, but you have to put the switch back when you are done doing the data entry to reconnect the VSS wires.
the push button software hack must be done each time you want to do this. the switch allows you to do it be flipping the switch on and off.
Old 01-29-07, 03:39 PM
sbrown02
sbrown02's Avatar
Originally Posted by 2thfixr
The first time, it took me about 30-40 minutes because I soldered everything and I had to figure out how long I wanted my wires to make the whole module easily to remove and install but look neat at the same time. The last time I took it apart to put the Vaistech module in, I really went all out and made it look like it was done at the factory by running all of my wires in appropriate length shrink wrap and wrapping the ends with the same sticky mesh fabric tape that the factory uses. That probably took me 20 mins by itself. I guess the answer to your question is. 20-30 minutes to do a hack job, 60+ min to do a nice perfect job.
Uhhhh.... put me down in the category of 60+ minutes AND a hack job. But hey, it works.
Jace7
Jace7's Avatar
hey snoopy? can you post me a pic of your switch? for turning on and off. I'd like to see up close where you did it.
thanks.
I'm just nervous, b/c I don't want to get it apart, then mess something up..... then not having it work like original or at all. bah
maybe it's easier than I am thinking it to be and I should just attempt. I can probably do it no problem, just not knowing... is well...... bah.
we'll see.
Is it worth doing just the DVD hack?
without the bluetooth and/or the NAV hack?
or will I regret not doing those two then have to do it later.... (if I even attempt it. )
Old 01-29-07, 08:43 PM
2thfixr
2thfixr's Avatar
Thanks.
Sure, I'll be over in 15 mins, why don't you wait for me outside.
Old 01-30-07, 11:38 AM
mattvds
mattvds's Avatar
I think i'm going to be trading in my ES350 for GS (hopefully get a good price on the 450h, otherwise 350) soon. I am also wonering about the Nav Hack. There are some really good pictures on the ES forum, I'm wondering if it will be the same? Also my biggest concern is does this mod void the warrantee. When I had my nav unit replaced in my ES (for climate commands), my invoice claimed the replacement cost was 10K!
Old 01-30-07, 12:57 PM
randomact
randomact's Avatar
where is the hack link for the gs350 step by step? Can someone please post up
rgardjr
01-26-11 11:13 PM
Zender
Canada
16
07-02-09 11:46 PM
dz302
02-18-09 11:27 PM
mochiball
02-03-06 11:44 AM
Quick Reply: the wire cut hack for DVD.
