Where NOT to put your key
In the 2007 GS 350 owner's manual, it says: "To avoid serious deterioration, do not leave the electronic key within 3 feet of ... recharging cell phone or cordless phone or table top lamps."
Huh???
Don't most people put their billfold, their keys and their cell phone on their charger next to their bedside lamp, so that you'll remember to pick up their keys, their wallet and their cell phone when heading out?
Is this REALLY a problem? Are you avoiding this, and, if not, are you experiencing any problems? I don't care about the lamp, but I would like to leave the cell phone on the charger beside my billfold and my keys.
Huh???
I had my key in the same pocket as my cell phone once and the car said "the key is not detected". I only had it happened once. Since then, I always leave them in separate pockets.
Pocket problem
How about the charging issue?
I'm guessing this is normal talk for RF interference. I wouldnt worry too much about it. But I can see it picking up some issues as its normally the smaller device that has less shielding.
Are others having problems or not?
Yes, BUT, if others are putting their billfold, their keys and their cell phone on their charger next to each other regularly, are you having problems or not? Thanks!
As stated, the warning is to minimize RF interference. I believe "serious deterioration" is referring to signal quality not damage to the key or your cell phone. Worst case scenario is that you will have to step closer to your car to unlock the door. It's just like when you put your cell phone too close to a cordless phone or a speakerphone, you hear a buzz on your regular phone if your cell phone is receiving text data or a call. It happens all the time at my office. If I place my cell phone too close to my Plantronics cordless headset, it will buzz like crazy. Similarly, if I place my Plantronics headset receiver too close to my speakerphone, both will buzz.
so if I always have my key in my pocket and have my phones clipped to my belt on the same side as the key, your saying this is a problem?
just need clarification... b
You must have a nextel.
They put out alot of power and cause devices to buzz more than my other cell phones.
but back to the question, no, I dont have any issues with my remote causing issues.
No problem there. I had key on top of my phone in the SAME pocket. That was the only time that it displayed "key not detected". Since you have your phone on the belt and the key is in the pocket, they are far apart enough that you should not have any issue.
Worst case scenario - the remote's range will be diminished and your cell phone signal won't be as strong. Oh yeah, I forgot to mention, if you keep your phone too close to the key for an extended period of time, the solder joints will melt and the PC board inside will catch fire causing the batteries in the remote to leak battery acid onto your skin eventually causing a gaping hole to form where bacteria will enter your body and a nasty infection will form which will then cause bacteremia which will ultimately lead to death. Outside of that it's not a problem.
I wouldn't worry about it.
Huh???
Huh???
Steve,
I'm glad you posted this because without intending to it seems you solved a mystery for me with keyless system. Nothing would work unless i got the FOB close to ignition button by holding against windshield over steering wheel area during a trip stop i made to Tampa area. From your post it seems it was due to me having a charger hooked up in the car cig lighter, well within the 3 feet of key FOB and for that matter within 2 feet of the entire keyless system though I thought it was off or at ready I should say. As others have indicated I think the outlined... do not do...is to avoid what may interfere with it working rather than do damage to the FOB.
Steve,
I wish more people would report in that they've tried put their cell phone on the charger next to their key and
1) They had no problem
OR
2) They had the following problems _____
