Trunk opener not responding
Hey guys,
I'm having an issue with my trunk opener. It does not open with the push of the button on my FOB nor the button inside of the car next to the gas door opener. When I manually insert my hidden key, the trunk operates normal. I don't think it's the motor because it still works when I close to trunk. Could this be a busted fuse?
Any input will be appreciated.
Thanks!
Thanks!
Nope, probably not busted - had same issue a few weeks ago. Make sure the 'valet security' button on left side in glove box did not get bumped. If it did, neither the fob or the drop panel will allow the trunk to open. Try pressing the button to the other setting and hit the fob or panel button. It fixed my problem and hopefully yours too!
