Question about wheels
That Is Typically What Alot Of People Are Running Here... Depending On If You Lower Or Not You Will Have Rubbing... I Have 245/30/20 (f) And 285/25/20 (r) But I Am Also Aggressively Lowered About 2-1/4" .. So If You're Not Going To Lower Then That Should Work Out Fine.. But If You Lower Anything Lower Than 1" You Will Probably Rub.... Just My $.02....hope That Helps..
I have to disagree with you on that. A lot of this has to depend on what offset you're running. Also, I think that Chivas Rus says that he's running 19" wheels so his overall size should be smaller than a person running 20"s. 275 seems to be the most popular size for that dimension and if your offsets are correct, you should be fine.
Curtis
Curtis
